menu_240113.rbf
- Shorter hsync/longer back ports at 15kHz
https://github.com/mist-devel/mist-bina ... cores/menu
firmware_240210
- Rescan directory, if the OSD size is changed
- Continously check SD card status, reinitialize if removed and reinserted
- USB: fix race condition between SOF IRQ check and reset
- Prevent stuck joystick when opening the OSD
firmware_240405
- Enable middle mouse button for minimig core (by retrofun)
- A more efficient method for retrieving the config string added (need mist-modules update in the cores)
- Allow bigger block sizes to be used by cores for VHD I/O
- Full wired XBox360 controller support
Commodore 16
c16_240405.rbf
- Open bus reads from some free ares (fixes Giana Sisters)
- Use PCM sound output from TED instead of PWM for better sound quality
- Update 1541
https://github.com/mist-devel/mist-bina ... /cores/c16
Commodore 16
c16_240405.rbf
- Update 1541
Lots of arcade cores from Gehstock's collection & CAPCOM arcades in Jotego's repo:
https://github.com/mist-devel/mist-bina ... res/arcade
Master System
SMS-Nuked_240716.rbf
- New core based on Nuked-SMS-FPGA
https://github.com/mist-devel/mist-bina ... r-mistsidi
Mega Drive
fpgagen_240716.rbf
- Fix IO area decoding (Ballz 3D)
- Auto-detect Virtua Racing cart
https://github.com/mist-devel/mist-bina ... es/fpgagen
Mega Drive
fpgagen_240716.rbf
