jorsus
Mensaje por jorsus » 06 Oct 2024, 23:17
TSConf (advanced ZX Spectrum-compatible platform)
TSConf_241005.rbf
- Mouse: add scroll support
- Tune JT49 to match sound output as on ZX-Multisound and zxtune
- Fix covox output to the left channel only
- Fix time counting when there is no USB-RTC on MIST
- Fix glitches while reading RTC in Basic
- Keyboard: change keyboard layout to same as in ZX Evolution
- Keyboard: fix arrow keys in Basic
- Keyboard: better handling of simultaneously pressed keys
- Keyboard: add fifo for scancodes to improve compatibility with some picky software
https://github.com/mist-devel/mist-bina ... res/tsconf
jorsus
Mensaje por jorsus » 09 Oct 2024, 10:26
Nintendo Entertainment System
nes_241008.rbf
- Real Zapper support (by UzixLS)
- X/Y as turbo fire buttons (by UzixLS)
- FAMICON keyboard support
- A few mapper support enhancements
https://github.com/mist-devel/mist-bina ... /cores/nes
jorsus
Mensaje por jorsus » 28 Nov 2024, 20:45
Advanced Basic Computer 80
ABC80_241128.rbf
- New core
https://github.com/mist-devel/mist-bina ... ores/abc80
ZX Spectrum 128K
zxspectrum_241128.rbf
- Add ZXUNO WiFi support (with the help of an ESP board on UART - thanks to Eugene Lozovoy)
- Use X/Y buttons as 7th/8th bits in kempston joystick (Eugene Lozovoy)
- Use the MIDI OUT pin for the AY GPIO (like on the original 128K machine)
- Some small tweaks and menu options (Eugene Lozovoy)
- Tweak SDRAM to try avoid contention when using the General Sound interface
https://github.com/mist-devel/mist-bina ... s/spectrum
Colecovision and SG-1000
colecovision_241128.rbf
- Fix 'blend' setting
https://github.com/mist-devel/mist-bina ... lecovision
