BBC Micro
bbc_251117.rbf
- Add Music5000 synthesizer by David Banks (thx slingshot2)
https://github.com/tdelage26/mist-binar ... /cores/bbc
BBC Micro
bbc_251118.rbf
- Added two disk drives support (thx slingshot2)
Super Nintendo
snes_mist_251119.rbf
- PPU: fix sprite evaluation during Force Blank (thx to srg320)
- PPU: Fixes for 16x32 & 32x64 sprites and tile count/flip (thx to paulb-nl)
With the undocumented sizes 16x32 and 32x64 two of the obj size signals
are active simultaneously. It seems that the Range and Time periods use
a mix of the two sizes for different checks.
Example: With a sprite size of 16x32 the sprite is still in range when
the H position is set to -16. Time treats the sprite as 16x16 but with H
position -16 it displays the tiles with horizontal offset 2 & 3 instead
of 0 & 1.
Normally with sprite interlace enabled, the sprite height is halved but
with a sprite size of 16x32 it is treated as 32x8 instead of 32x16.
With tile flip it only inverts the tile count bits according to sprite size.
https://github.com/tdelage26/mist-binar ... cores/snes
bbc_251118.rbf
Super Nintendo
of 0 & 1.
BBC Micro
bbc_251226.rbf
- Add 65C102 Tube Co-Pro (slingshot2)
bbc_251226.rbf
Coleco Adam
adam_260105.rbf
- Ported from Calypso
https://github.com/tdelage26/mist-binar ... cores/adam
adam_260105.rbf
Matra-Hachette Alice MC-10
alice_MiST_260108.rbf
- Ported from Teiram's Calypso cores.
https://github.com/tdelage26/mist-binar ... ce%20MC-10
Tatung Einstein
einstein_MiST_260107.rbf
https://github.com/tdelage26/mist-binar ... s/einstein
Sord M5
sordm5_MiST_260108.rbf
https://github.com/tdelage26/mist-binar ... res/sordm5
Tatung Einstein
Sord M5
Amstrad CPC 6128
Amstrad_260109.rbf
- Dandantor mini-ROM support
https://github.com/mist-devel/mist-bina ... mstrad_alt
BBC Micro Model B/Master
bbc_260109.rbf
- ACIA with partial Serproc support
- Music5000 synthesizer (from David Banks)
- Two disk drive support
https://github.com/mist-devel/mist-bina ... /cores/bbc
Amstrad_260109.rbf
bbc_260109.rbf
Amstrad CPC 6128
Amstrad_260114.rbf
- Fix "Perico delgado Maillot Amarillo (S) (1989) [Original]" - Some disks have one additional empty track as copy-protection scheme
- Fix "Fugitif (F) (1991) (CPM)" - bit 6 of SENSE DRIVE STATUS must react when the user changes discs
https://github.com/tdelage26/mist-binar ... mstrad_alt
Amstrad_260114.rbf
