Mensaje por desUBIKado » 04 Abr 2019, 18:50
2019.04.04
RealLarry, usuario de Atari Forum, ha sintetizado el core de pruebas de Slingshot de Atari ST a ciclo exacto basado en el core de ijor para la MiSTer, por lo que todos podemos probarlo.
Mensaje por jorsus » 25 Jul 2020, 19:36
Nuevo Firmware:
firmware_200725
- Fix long-standing ADF write corruption bug
- Generic USB-RTC support
Y nuevos cores de Amiga y Atari ST:
https://github.com/mist-devel/mist-bina ... inimig-aga
https://github.com/mist-devel/mist-bina ... es/mistery
**minimig_mist_200725**
- Don't read the mouse twice
- USB-RTC support (read-only)
**mistery-200725**
- FDC force IRQ command should start the motor
Mensaje por jorsus » 09 Ago 2020, 22:08
archimedes_200808.rbf
Fix audio clock
Add reset to Amber (by Robert Peip)
https://github.com/mist-devel/mist-bina ... archimedes
zxspectrum_200809.rbf
ULA and CPU timing fixes
Implement the snow effect
Update PSG
Beeper + PSG volume mixing adjustment
Mensaje por jorsus » 24 Ago 2020, 22:06
Gameboy
gb_200810.rbf
Lot of fixes from paulb-nl and brNX. GBC games are really good!
https://github.com/mist-devel/mist-bina ... es/gameboy
Atari 2600
a2600_200812.rbf
TIA fixes: Playfield mirroring, playfield score flag, (no) collisions in blanks. Canyon Bomber, Tutankham, Caverns games are fixed
https://github.com/mist-devel/mist-bina ... res/a26001
Genesis/Mega Drive core
fpgagen_200821.rbf
Bus arbitration rework
ZRAM access rework
Pages in OSD
Update jt12
DMA COPY cycle-exactness
https://github.com/mist-devel/mist-bina ... es/fpgagen
OneChipMSX
msx_mist_200821.rbf
CPU update
RTC support
https://github.com/mist-devel/mist-bina ... /cores/msx
zxspectrum_200822.rbf
Further ULA timing fixes (Timing_Tests-128k_v.1.0)
Increase GS clock to 14 MHz
Fix hires Timex mode
Mensaje por jorsus » 31 Ago 2020, 23:51
Atari 2600
a2600_200831.rbf
TIA: fix divider by 6 (E.T., but affects all C,D,E audio waveforms)
Update the DPC mask flags after changing the counters (Pitfall II)
TIA: transparent latches for the color registers (D.K.VCS)
TIA: don't apply pf_score when pf_priority=1 (Bobby is Going Home)
https://github.com/mist-devel/mist-bina ... ores/a2600
Mensaje por jorsus » 08 Sep 2020, 08:24
Texas Instruments TI-99/4A
Ti994a_200907.rbf
New core
https://github.com/mist-devel/mist-bina ... res/ti994a
Mensaje por jorsus » 08 Sep 2020, 21:43
Ti994a_200908.rbf
Cart file type auto detection
Mask cart unused address bits (detected from .d type)
Add some keyboard shortcuts
Mensaje por jorsus » 23 Sep 2020, 21:07
Amiga
minimig_mist_rtg_200923.rbf
RTG and C2P support by Alastair M. Robinson
TG68K updates with stack frame fixes in 68010+ modes
Mensaje por jorsus » 25 Sep 2020, 03:09
El nuevo core de Amiga RTG no funciona bien en mi monitor que no soporta 49Hz.
Despues de pasar la incidencia a Alastair M. Robinson ha tenido la amabilidad de hacer un core nuevo.
Si alguien mas tiene el mismo problema aqui les dejo el enlace
http://www.mediafire.com/file/x7m51afztrwge45/file
