jorsus
ULA
Mensaje por jorsus » 01 Oct 2022, 22:02
Mattel Intellivision
Intellivision_20221001.rbf
- Updated ROM loading, should now work with Intellicart .rom files.
https://github.com/mist-devel/mist-bina ... ellivision
jorsus
ULA
Mensaje por jorsus » 17 Oct 2022, 20:43
firmware_221017
- Tweak USB storage recognition (by retrofun)
- Show information of booted storage device in OSD system menu (by retrofun)
- Increase max. core/dir/vhdname size to 16 in ARC files
- Fix F12 code in PS2/set1 (affects Next186)
- Use the proper CRC value for CMD12 in SD card multiple read access
jorsus
ULA
Mensaje por jorsus » 22 Oct 2022, 11:08
Commodore VIC-20
vic20_221022.rbf
- Update 1541
- Fix VIA's port latching (Robotic Liberation!)
- Update MiST modules
https://github.com/mist-devel/mist-bina ... ores/vic20
jorsus
ULA
Mensaje por jorsus » 24 Oct 2022, 23:53
ZX Spectrum 48K, 128K, +3 and Pentagon 128
zxspectrum_221024.rbf
- ESXDOS ROM updated to 0.8.9
- Currah uSpeech support based on Dar's SP0256 implementation
jorsus
ULA
Mensaje por jorsus » 30 Oct 2022, 23:31
Oric 48K
Oric_221030.rbf
- Some updates and cleanups since the last released version
- Internal TAP playback support
- VIA6522 updated to the latest from the Commodore cores
- ROM resides in SDRAM now (an oric.rom is required)
https://github.com/mist-devel/mist-bina ... cores/oric
jorsus
ULA
Mensaje por jorsus » 04 Nov 2022, 19:09
Oric 48K
Oric_221104.rbf
- Fix the refresh logic in the SDRAM controller
jorsus
ULA
Mensaje por jorsus » 09 Nov 2022, 16:26
Commodore 64
C64_220530.rbf
- Adjust blanking/sync timings according to prelimiary VIC-II datasheet/Christian Bauer's VIC-II docs
- T65: rework interrupt dispatching
- CPUPort: bit 5 is low when input
- Update VIA
- C64.R02 can be used as a default cart image
jorsus
ULA
Mensaje por jorsus » 13 Nov 2022, 19:32
Apple //e
apple2e_221113.rbf
- Fix the floating bus values
- Correct the vertical counter advancing (make Cycle Counting Megademo from VMW work)
- NTSC/PAL mode switch option
- Update T65 and mist-modules
https://github.com/mist-devel/mist-bina ... s/appleIIe
jorsus
ULA
Mensaje por jorsus » 17 Nov 2022, 15:41
Elan Enterprise
ep128_221116.rbf
- New core by Kyp
https://github.com/mist-devel/mist-bina ... enterprise
jorsus
ULA
Mensaje por jorsus » 22 Nov 2022, 21:49
firmware_221122
- Fix ASIX USB network adapter detection
- Fix crash when Minimig is loaded from a subdirectory
- Some OSD drawing code optimizations
- Load a default ARC file when the FPGA is initialized from JTAG
- Give time to initialize the FPGA when loaded from JTAG
