jorsus
ULA
Mensaje por jorsus » 13 Ene 2024, 21:53
menu_240113.rbf
- Shorter hsync/longer back ports at 15kHz
https://github.com/mist-devel/mist-bina ... cores/menu
jorsus
ULA
Mensaje por jorsus » 10 Feb 2024, 20:11
firmware_240210
- Rescan directory, if the OSD size is changed
- Continously check SD card status, reinitialize if removed and reinserted
- USB: fix race condition between SOF IRQ check and reset
- Prevent stuck joystick when opening the OSD
jorsus
ULA
Mensaje por jorsus » 05 Abr 2024, 23:46
firmware_240405
- Enable middle mouse button for minimig core (by retrofun)
- A more efficient method for retrieving the config string added (need mist-modules update in the cores)
- Allow bigger block sizes to be used by cores for VHD I/O
- Full wired XBox360 controller support
Commodore 16
c16_240405.rbf
- Open bus reads from some free ares (fixes Giana Sisters)
- Use PCM sound output from TED instead of PWM for better sound quality
- Update 1541
https://github.com/mist-devel/mist-bina ... /cores/c16
jorsus
ULA
Mensaje por jorsus » 22 Jun 2024, 18:00
Lots of arcade cores from Gehstock's collection & CAPCOM arcades in Jotego's repo:
https://github.com/mist-devel/mist-bina ... res/arcade
jorsus
ULA
Mensaje por jorsus » 11 Jul 2024, 20:04
Arcade - Data East Burger Time Hardware
https://github.com/mist-devel/mist-bina ... 20Hardware
