Amstrad CPC 6128
amstrad_250910_r006.5b.rbf
- Screen C64 wip
- Screen C64 wip
Amstrad CPC 6128
amstrad_250915_r006.7b.rbf
- C64 screen with rotate
Amstrad CPC 6128
amstrad_250924_r006.8b.rbf
-C64 palette algo.
-Tested with Winzards Lair
-C64 palette algo.
Amstrad CPC 6128
amstrad_251015_r006.9b.rbf
-C64 palette generated by C64_to_CPC_palette[Eclipse_Java]
-OSD>Screen:C64
-OSD>Screen:C64
Amstrad CPC 6128
amstrad_251016_r006.10b.rbf
-C64 PALETTE mapping fix
Amstrad CPC 6128
amstrad_251017_r006.11.rbf
-palette C64
-rollback OSD "Original", use the setting files to enable original signal.
-scandoubler in text setting instead of OSD
thanks to Robert Kacsich for tests and ideas
-palette C64
Amstrad CPC 6128
amstrad_251027_r006.11.1.rbf
-C64 palette color adapted
Super Nintendo
snes_mist_251028.rbf
PPU updated in SNES core thx to Srg320
-fix fetching of disabled bg layers
(Pocky & Rocky: title)
-increase the pixel output pipeline
(Wild Guns: pixel)
-implement the behavior of the Color Math unit when changing settings
(Shounen Ashibe - Goma-chan no Yuuenchi Daibouken, Pocky & Rocky: pixels)
https://github.com/tdelage26/mist-binar ... cores/snes
(Wild Guns: pixel)
Super Nintendo
snes_mist_251029.rbf
-PPU : BG fetch in VBlank fixes (Pocky&Rocky title)
Pocky & Rocky title screen pixels should change from white to purple when Options menu appears.
Thanks to paulb-nl for the fix !
Amstrad PCW
PCW_MiST_251111.rbf
- Change bleeper frequence to 4Khz after measures of a real PCW thx to Manuel Teira
- Fix audio mixed to avoid saturation ( fix target renegade) thx to albconde
https://github.com/tdelage26/mist-binar ... AmstradPCW
PCW_MiST_251111.rbf
