jorsus
Mensaje por jorsus » 26 May 2026, 17:42
Amstrad CPC
amstrad_260523_r007.9.5.rbf
- scancrtc 1
jorsus
Mensaje por jorsus » 19 Jun 2026, 12:35
New Commodore 128 core
c128.rbf & c128_jiffy.rbf
- 8502 and Z80 CPUs
- Switchable PAL/NTSC video output format
- VDC with 16KB ram
- One 1541 Floppy Drive (D64 and G64 files format only) <--- Serial mode only
- Support for memory injection format (CRT/TAP/PRG)
- One single 6581 SID chip
- Audio tape (Datasette) input support
- Mouse / Paddle / Joystick support
- C64 mode switchable from the OSD
- 40/80 columns mode switchable from the OSD (requires soft reset after selection)
- GeoRAM 4MB cartridge support
- Support Jiffy DOS for quicker floppy drive read in both C128 and C64 mode (require separate binaries and ROM BIOS)
https://github.com/tdelage26/mist-binar ... cores/c128
