Pano Logic G1: Programa VHDL "Hola Mundo"
Cores exclusivos para la Pano Logic G1 ó G2 (sus cores NO son intercambiables)
Mensaje por benitoss » 22 Dic 2018, 07:15
Aqui teneis el VHDL "Hola mundo" para la Pano Logic G1 (VGA)
El ejemplo hace parpadear los LEDs rojo y verde y alternativamente el LED azul
Archivo hello_world.vhdl
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity hello_world is
    port (
        clk     		: in std_logic;
        led_green         : out std_logic;
	led_blue           : out std_logic;
	led_red             : out std_logic
    end hello_world;
    architecture rtl of hello_world is
        constant CLK_FREQ : integer := 20000000;
        constant BLINK_FREQ : integer := 1;
        constant CNT_MAX : integer := CLK_FREQ/BLINK_FREQ/2-1;
        signal cnt      : unsigned(24 downto 0);
        signal blink    : std_logic;
    begin
        process(clk)
        begin
            if rising_edge(clk) then
                if cnt=CNT_MAX then
                    cnt <= (others => '0');
                    blink <= not blink;
                    cnt <= cnt + 1;
                end if;
            end if;
        end process;
        led_red <= NOT blink;
		  led_green <= NOT blink;
		  led_blue <= blink;
    end rtl;
Archivo constrain file hello_world.ucf
# 100MHZ Oscillator
#NET "osc_clk" LOC = U10 |IOSTANDARD = LVCMOS33;
# IDT ICS307 Clock Generator
#NET "idt_sclk"   LOC = F2  |IOSTANDARD = LVCMOS33;
#NET "idt_strobe" LOC = G5  |IOSTANDARD = LVCMOS33;
#NET "idt_data"   LOC = F1  |IOSTANDARD = LVCMOS33;
#NET "idt_iclk"   LOC = J2  |IOSTANDARD = LVCMOS33;
NET "clk"   LOC = J4  |IOSTANDARD = LVCMOS33;
# Button
#NET "button"  LOC = R7  |IOSTANDARD = LVCMOS33;
# LEDs
NET "led_green" LOC = H1  |IOSTANDARD = LVCMOS33;
NET "led_blue"  LOC = L1  |IOSTANDARD = LVCMOS33;
NET "led_red"   LOC = L3  |IOSTANDARD = LVCMOS33;   # Is this an input or an output, coming from the Micrel PHY?
En el adjunto, aparte de las fuentes, teneis el bit y el svf file para poder programarlo directamente.
Saludos
hello_world.zip
(160.12 KiB) Descargado 1557 veces
Volver a “Cores”
