Mensaje por jorsus » 02 Jul 2021, 14:14
Texas Instruments TI-99/4A
Ti994a_210701.rbf
- fix FDC image handling
https://github.com/mist-devel/mist-bina ... res/ti994a
Mensaje por jorsus » 04 Jul 2021, 20:06
Sinclair QL
ql_210703.rbf
- Switchable speed to get closer to original QL speed.
- BUS improvements to attempt reduction in bus access speed including use of clkena_in to replicate DTACK waits.
- Reworked IPC communication logic in ZX8302 and added a COMDATA latch.
- IPC code uses Hermes, fixes missing key-presses.
- Eliminate most async clocks.
https://github.com/mist-devel/mist-bina ... r/cores/ql
Mensaje por jorsus » 06 Jul 2021, 02:31
PC Engine/TurboGrafx-16
tgfx16_210705.rbf
- New SDRAM controller and cofi module by robinsonb5
- Fix sprite rendering in hires mode
- Source tree merged with the Turbo Chameleon port
https://github.com/mist-devel/mist-bina ... s/pcengine
Mensaje por jorsus » 12 Jul 2021, 08:02
Atari ST
MiSTery-210711.rbf
- Fix extra RAM selection (works with TG68K now)
- Various updates of components (FX68K, TG68K, FDC)
https://github.com/mist-devel/mist-bina ... es/mistery
Mensaje por jorsus » 13 Jul 2021, 01:03
MSX2+
msx_mist_210712.rbf
- Update common MiST components - support multiple write SD Card command
https://github.com/mist-devel/mist-bina ... /cores/msx
Mensaje por jorsus » 14 Jul 2021, 02:13
Sinclair QL
ql_210713.rbf
- Improved speed to be near the original QL hardware speed.
Mensaje por jorsus » 15 Jul 2021, 23:40
firmware_210715
- Bidirectional PS2 support (accepts some keyboard/mouse control commands)
- Add total number of sector reporting for IDE LBA mode (fixes HDToolBox size reporting)
- New Minimig features menu (by retrofun)
- Menu scrolling fix with subpages
- Directory listing fix when one directory is a prefix of another
PC AT
Next186_210715.rbf
- New core
https://github.com/mist-devel/mist-bina ... es/next186
Mensaje por jorsus » 25 Jul 2021, 12:59
Sinclair QL
ql_210724.rbf
- Improved video positioning.
Mensaje por jorsus » 28 Jul 2021, 13:24
firmware_210727
- Add more PS2 mouse commands (fixes some Next186 mouse using progs - by retrofun)
- Don't send a mount msg to the core when mounting is failed (fixes Next186 native SD use)
- Fix core.arc loading
Amiga RTG
minimig_mist_rtg_210727.rbf
- Don't freeze on writing 256 sectors
- Make the secondary IDE disabling effective
- Configurable audio filter mode & power LED off-state (by retrofun)
https://github.com/mist-devel/mist-bina ... inimig-aga
Mensaje por jorsus » 02 Ago 2021, 21:56
PC AT
Next186_210802.rbf
- Many improvements in PIC, PIT and PC Speaker
- MPU-401 interface (by squidrpi)
- More frequent cache flushes reducing VGA artifacts (however reducing the performance, too)
- EGA/VGA VDE register fix
- Joystick support
- Cache the whole phyisical address space
- NMI button (useful for Turbo Debugger)
The BIOS also needs to be updated!
