Mensaje por jorsus » 13 Ene 2023, 21:59
Videoton TV Computer
TVC_230113.rbf
- Enhanced from the original core (originally by József László)
- Rewritten some parts to synchronous code
- Updated the various components, like the T80 CPU and MC8645 CRTC
- Cartridge and FDC support
- Some additional fixes, like digi sound is working now
- 15kHz (original) and 31kHz(scandoubled) video outputs are supported in one core
https://github.com/mist-devel/mist-bina ... /cores/tvc
Mensaje por jorsus » 23 Ene 2023, 21:41
ZX Spectrum 128K
zxspectrum_230122.rbf
- Replace WD1772
- Fix PlusD interface
- Disable Covox/Sndrive during TRDOS/PlusD use
Mensaje por jorsus » 02 Mar 2023, 11:23
TVC_230228.rbf
- Fix sound divider and interrupt generator
Commodore 64
C64_230228.rbf
- Add a normal reset without removing the cartridge
- Fix cartridge (C64.R02) file autoload
- Add support for cart type 36 (Retro Replay)
- Fix a regression with VIC-II data fetch when AEC is asserted
Mensaje por jorsus » 01 Abr 2023, 00:41
ZX Next
ZXN-230331.rbf
Rebase to the latest ISSUE4 release
Update mist-modules
https://github.com/mist-devel/mist-bina ... /cores/zxn
OneChipMSX
msx_mist-230331.rbf
Update to OCM-PLD 3.9.1
Add a Mount VHD option to the OSD
Fix the SD Card emulation for Nextor kernels
https://github.com/mist-devel/mist-bina ... /cores/msx
Mensaje por jorsus » 03 Abr 2023, 14:28
Commodore 64
C64_230402.rbf
- Allow to set the mouse port manually in the OSD
- PRG injection should set some ZP variables +1 beyond the end
- VIC-II: fix NTSC bus access slots
Mensaje por jorsus » 20 Abr 2023, 23:44
Super Nintendo
snes_mist_230420.rbf
- Update with the latest upstream changes since the last release
- SFC player option (exit from it with reset)
https://github.com/mist-devel/mist-bina ... cores/snes
Mensaje por jorsus » 22 Abr 2023, 11:20
firmware_230421
- New system status menu page (by retrofun)
- IDE improvements for non-Amiga use cases
- Disable joysticks when OSD is open
PCXT_mist_230421.rbf
- New core
https://github.com/mist-devel/mist-bina ... cores/pcxt
Mensaje por jorsus » 04 May 2023, 16:33
Super Nintendo
snes_mist_230503.rbf
- Fix in the scandoubler to handle the NTSC short line
Mensaje por jorsus » 06 May 2023, 08:17
firmware_230505
- Handle BUTTONS line in ARC files (use a recent MRA tool to add it to ARCs)
- Display the real RBF name in the system menu if the core is loaded from an ARC file
Mensaje por jorsus » 12 May 2023, 17:00
OneChipMSX
msx_mist_230512.rbf
- Fix the MIDI/WiFi module use
- Option to choose between MIDI/WiFi mode for the UART pins
