Mensaje por jorsus » 06 Oct 2024, 23:17
TSConf (advanced ZX Spectrum-compatible platform)
TSConf_241005.rbf
- Mouse: add scroll support
- Tune JT49 to match sound output as on ZX-Multisound and zxtune
- Fix covox output to the left channel only
- Fix time counting when there is no USB-RTC on MIST
- Fix glitches while reading RTC in Basic
- Keyboard: change keyboard layout to same as in ZX Evolution
- Keyboard: fix arrow keys in Basic
- Keyboard: better handling of simultaneously pressed keys
- Keyboard: add fifo for scancodes to improve compatibility with some picky software
https://github.com/mist-devel/mist-bina ... res/tsconf
Mensaje por jorsus » 09 Oct 2024, 10:26
Nintendo Entertainment System
nes_241008.rbf
- Real Zapper support (by UzixLS)
- X/Y as turbo fire buttons (by UzixLS)
- FAMICON keyboard support
- A few mapper support enhancements
https://github.com/mist-devel/mist-bina ... /cores/nes
Mensaje por jorsus » 28 Nov 2024, 20:45
Advanced Basic Computer 80
ABC80_241128.rbf
- New core
https://github.com/mist-devel/mist-bina ... ores/abc80
ZX Spectrum 128K
zxspectrum_241128.rbf
- Add ZXUNO WiFi support (with the help of an ESP board on UART - thanks to Eugene Lozovoy)
- Use X/Y buttons as 7th/8th bits in kempston joystick (Eugene Lozovoy)
- Use the MIDI OUT pin for the AY GPIO (like on the original 128K machine)
- Some small tweaks and menu options (Eugene Lozovoy)
- Tweak SDRAM to try avoid contention when using the General Sound interface
Colecovision and SG-1000
colecovision_241128.rbf
- Fix 'blend' setting
https://github.com/mist-devel/mist-bina ... lecovision
Mensaje por jorsus » 13 Dic 2024, 14:55
ZX Spectrum 128K
zxspectrum_241203.rbf
- Allow disabling Covox/SounDrive
Mensaje por jorsus » 16 Ene 2025, 12:12
PCEngine
tgfx16_250115.rbf
- Updates from upstream (by dshadoff and srg320)
https://github.com/mist-devel/mist-bina ... s/pcengine
Commodore 16
c16_250114.rbf
- Implement the MOS 6551 UART
https://github.com/mist-devel/mist-bina ... /cores/c16
Exidy Sorcerer
Sorcerer_250114.rbf
- New core
https://github.com/mist-devel/mist-bina ... s/sorcerer
Mensaje por jorsus » 17 Ene 2025, 16:07
firmware_250117
- Fix incorrect joystick numbering when joystick_disable_swap=1 (by UzixLS)
- Fix handling multiple report ID's in the HID descriptors
- Fix the obsolete PLAY AUDIO TRACK/INDEX ATAPI command
- Clean up USB button reporting
Mensaje por jorsus » 14 Feb 2025, 01:43
Tandy CoCo - Dragon32/64
CoCo2_250212.rbf
- New core
https://github.com/mist-devel/mist-bina ... ores/coco2
Mensaje por jorsus » 22 Feb 2025, 14:19
Advanced ZX Spectrum-compatible platform
TSConf_250219.rbf
- Always use cache for ROM - this fixes Bomberman Evolution
- MIDI output is now handled on both AY chips
Mensaje por jorsus » 01 Mar 2025, 01:57
Apple //e
apple2e_250226.rbf
- Selectable color palettes by Newsdee
- CFFA 2.0 compatible IDE interface in Slot 7
- Super Serial Card RS232 interface in Slot 2
https://github.com/mist-devel/mist-bina ... s/appleIIe
Mensaje por jorsus » 09 Mar 2025, 21:44
Commodore 64
C64_250308.rbf
- Exchange control port connections (port1 -> PB, port2 -> PA)
- Implement NEOS Mouse
- Fix 1351 for Duck Hunt (MSB always '1')
