Amstrad CPC
amstrad_260523_r007.9.5.rbf
- scancrtc 1
New Commodore 128 core
c128.rbf & c128_jiffy.rbf
- 8502 and Z80 CPUs
- Switchable PAL/NTSC video output format
- VDC with 16KB ram
- One 1541 Floppy Drive (D64 and G64 files format only) <--- Serial mode only
- Support for memory injection format (CRT/TAP/PRG)
- One single 6581 SID chip
- Audio tape (Datasette) input support
- Mouse / Paddle / Joystick support
- C64 mode switchable from the OSD
- 40/80 columns mode switchable from the OSD (requires soft reset after selection)
- GeoRAM 4MB cartridge support
- Support Jiffy DOS for quicker floppy drive read in both C128 and C64 mode (require separate binaries and ROM BIOS)
https://github.com/tdelage26/mist-binar ... cores/c128
- 8502 and Z80 CPUs
- VDC with 16KB ram
Amstrad CPC
amstrad_260607_r007.9.6.rbf
- Still the one - impact CRTC1 nicely detect
- CRTC0 is badly implemented (no buffers)
Amstrad CPC
amstrad_260628_r007.9.7.rbf
- CRTC read Sogely
- TODO CRTC write masks
- CRTC read Sogely
Amstrad CPC
amstrad_260710_r007.9.8.rbf
- CRTC1 write mask
- Point barre
- CRTC1 write mask
- Point barre
IMSAI 8080
imsai8080.rbf
- The famous clone of the Altair 8800 featured in the 1983 movie "Wargames"
- Ported to full SDRAM from Teiram Calypso core (no PSRAM required)
https://github.com/tdelage26/mist-binar ... /imsai8080
imsai8080.rbf
Commodore 64
C64_260721.rbf
- SID Audio Chip Replacement
Replaced the old dual-SID implementation (VHDL 6581 + Verilog sid8580) with the MiSTer reDIP-SID engine released several weeks ago (full Verilog)
- Digifix bug correction (was previously wrongly active for 8580 and not for 6581 when it should have been reverse way)
- Audio filter fix
When off, all voices bypass the SVF through the direct path which is supposedly the correct hardware behaviour.
I also decoupled digifix from the filter toggle (independant features now)
- Colour palette
Replaced fpga64_rgbcolor.vhd with the MiSTer version allowing palette selection. Added the necessary port through fpga64_sid_iec entity to c64colors instantiation as well as OSD menu entry in the "audio/video" section to allow palette selection.
Available choices are : Colodore, Ultimate, Pepto-PAL, Vice, Vice6569R1, Vice6569R5, Vice8565R2 and Lemon64.
Default palette is now Colodore as on MiSTer (was Pepto-PAL on the old MiST core)
https://github.com/tdelage26/mist-binar ... res/fpga64
C64_260721.rbf
- Audio filter fix
- Colour palette
