Si podéis darme indicaciones de porqué falla al compilarlo con quartus ii.
sacado el código de:
https://github.com/bdeloeste/Character- ... arModule.v
el codigo es este:
`timescale 1ns / 1ps
module vh_sync (
input wire clk,
input wire clr,
output wire hsync,
output wire vsync,
output reg [3:0] red,
output reg [3:0] green,
output reg [3:0] blue
* These are the parameters for a 640x480 px display (60Hz refresh rate)
parameter hpixels = 800;
parameter vlines = 521;
parameter hpulse = 96;
parameter vpulse = 2;
parameter hbp = 144;
parameter hfp = 784;
parameter vbp = 31;
parameter vfp = 511;
reg [9:0] hc;
reg [9:0] vc;
reg [1:0] pxclk;
wire inH = (hc < 640);
wire inV = (vc < 480);
wire inDisplay = inH && inV;
always @ (posedge clk) pxclk = pxclk + 1;
wire pclk;
assign pclk = pxclk[1]; // 25MHz Pixel Clock
* Enable the horizontal and vertical counters to count when they are in the
* range of the display.
always @ (posedge pclk or posedge clr)
begin
if (clr == 1)
begin
hc <= 0;
vc <= 0;
begin
if (hc < hpixels - 1)
hc <= hc + 1;
begin
hc <= 0;
if (vc < vlines - 1)
vc <= vc + 1;
vc <= 0;
assign hsync = (hc < hpulse) ? 0:1;
assign vsync = (vc < vpulse) ? 0:1;
* This always block is used to display all characters (A-Z, 0-9)
always @ (*)
begin
if (vc >= vbp & vc < vfp & hc >= hbp & hc < hfp)
begin
char(0, 150, 150);
char(1, 160, 150);
char(2, 170, 150);
char(3, 180, 150);
char(4, 190, 150);
char(5, 200, 150);
char(6, 210, 150);
char(7, 220, 150);
char(8, 230, 150);
char(9, 240, 150);
char(10, 250, 150);
char(11, 150, 170);
char(12, 160, 170);
char(13, 170, 170);
char(14, 180, 170);
char(15, 190, 170);
char(16, 200, 170);
char(17, 210, 170);
char(18, 220, 170);
char(19, 230, 170);
char(20, 240, 170);
char(21, 250, 170);
char(22, 150, 190);
char(23, 160, 190);
char(24, 170, 190);
char(25, 180, 190);
char(26, 150, 210);
char(27, 160, 210);
char(28, 170, 210);
char(29, 180, 210);
char(30, 190, 210);
char(31, 200, 210);
char(32, 210, 210);
char(33, 220, 210);
char(34, 230, 210);
char(35, 240, 210);
if (!inDisplay)
begin
red = 0;
green = 0;
blue = 0;
* Implemented a function to draw a white line whenever vc and hc are
* in the domain of the x-start, y-start and x-end, and y-end coordinates.
function draw;
input [9:0] xStart;
input [9:0] yStart;
input [9:0] xEnd;
input [9:0] yEnd;
input [11:0] color;
begin
if (vc >= (vbp + yStart) && vc < (vbp + yEnd) && hc >= (hbp + xStart) && hc < (hbp + xEnd))
begin
red = color[3:0];
green = color[7:4];
blue = color[11:8];
if (!inDisplay)
begin
red = 0;
green = 0;
blue = 0;
endfunction
* char function to manually draw each character on a 9x9 pixel block
function char;
input [5:0] charVal;
input [9:0] x, y;
reg [11:0] white = 12'hFFF;
begin
case(charVal)
6'b000000: // A
begin
draw(x + 2, y, x + 5, y + 1, white);
draw(x + 1, y + 1, x + 6, y + 2, white);
draw(x, y + 2, x + 2, y + 9, white);
draw(x + 2, y + 4, x + 5, y + 6, white);
draw(x + 5, y + 2, x + 7, y + 9, white);
6'b000001: // B
begin
draw(x, y, x + 5, y + 2, white);
draw(x + 5, y + 2, x + 7, y + 4, white);
draw(x + 2, y + 4, x + 5, y + 5, white);
draw(x + 5, y + 5, x + 7, y + 8, white);
draw(x + 2, y + 8, x + 5, y + 9, white);
6'b000010: // C
begin
draw(x + 2, y, x + 6, y + 1, white);
draw(x + 1, y + 1, x + 2, y + 2, white);
draw(x + 6, y + 1, x + 7, y + 2, white);
draw(x, y + 2, x + 2, y + 8, white);
draw(x + 1, y + 8, x + 6, y + 9, white);
draw(x + 6, y + 7, x + 7, y + 8, white);
6'b000011: // D
begin
draw(x, y, x + 5, y + 1, white);
draw(x, y + 1, x + 2, y + 9, white);
draw(x + 5, y + 1, x + 6, y + 2, white);
draw(x + 6, y + 2, x + 7, y + 7, white);
draw(x + 5, y + 7, x + 6, y + 8, white);
6'b000100: // E
begin
draw(x, y, x + 7, y + 1, white);
draw(x + 2, y + 8, x + 7, y + 9, white);
6'b000101: // F
begin
draw(x + 2, y + 3, x + 5, y + 4, white);
6'b000110: // G
begin
draw(x + 1, y, x + 6, y + 1, white);
draw(x, y + 1, x + 2, y + 8, white);
draw(x + 4, y + 5, x + 5, y + 6, white);
6'b000111: // H
begin
draw(x, y, x + 2, y + 9, white);
draw(x + 5, y, x + 7, y + 9, white);
6'b001000: // I
begin
6'b001001: // J
begin
draw(x + 5, y, x + 7, y + 8, white);
draw(x, y + 6, x + 1, y + 8, white);
6'b001010: // K
begin
draw(x + 5, y + 3, x + 6, y + 4, white);
draw(x + 5, y + 5, x + 6, y + 6, white);
draw(x + 6, y, x + 7, y + 3, white);
draw(x + 6, y + 6, x + 7, y + 9, white);
6'b001011: // L
begin
draw(x + 2, y + 7, x + 7, y + 9, white);
6'b001100: // M
begin
draw(x + 1, y, x + 3, y + 1, white);
draw(x + 4, y, x + 6, y + 1, white);
draw(x, y + 1, x + 7, y + 2, white);
draw(x + 3, y + 2, x + 4, y + 9, white);
6'b001101: // N
begin
draw(x + 2, y + 1, x + 3, y + 2, white);
draw(x + 3, y, x + 6, y + 1, white);
draw(x + 6, y + 1, x + 7, y + 9, white);
6'b001110: // O
begin
draw(x + 5, y + 1, x + 7, y + 8, white);
6'b001111: // P
begin
draw(x + 6, y + 2, x + 7, y + 4, white);
draw(x + 5, y + 4, x + 6, y + 5, white);
draw(x + 2, y + 5, x + 5, y + 6, white);
6'b010000: // Q
begin
draw(x + 5, y + 1, x + 7, y + 7, white);
draw(x + 1, y + 8, x + 7, y + 9, white);
draw(x + 3, y + 6, x + 4, y + 7, white);
draw(x + 4, y + 7, x + 6, y + 8, white);
6'b010001: // R
begin
draw(x + 2, y + 5, x + 6, y + 6, white);
6'b010010: // S
begin
draw(x, y + 1, x + 1, y + 4, white);
draw(x + 6, y + 1, x + 7, y + 3, white);
draw(x + 1, y + 4, x + 6, y + 5, white);
draw(x + 6, y + 5, x + 7, y + 8, white);
6'b010011: // T
begin
draw(x, y, x + 7, y + 2, white);
draw(x + 3, y + 2, x + 5, y + 9, white);
6'b010100: // U
begin
draw(x, y, x + 2, y + 8, white);
draw(x + 1, y + 7, x + 6, y + 9, white);
6'b010101: // V
begin
draw(x, y, x + 1, y + 5, white);
draw(x + 6, y, x + 7, y + 5, white);
draw(x + 1, y + 4, x + 2, y + 7, white);
draw(x + 5, y + 4, x + 6, y + 7, white);
draw(x + 3, y + 6, x + 4, y + 8, white);
draw(x + 5, y + 6, x + 6, y + 8, white);
draw(x + 4, y + 8, x + 5, y + 9, white);
6'b010110: // W
begin
draw(x, y, x + 1, y + 8, white);
draw(x + 6, y, x + 7, y + 8, white);
draw(x + 3, y + 3, x + 4, y + 8, white);
draw(x, y + 8, x + 7, y + 9, white);
6'b010111: // X
begin
draw(x, y, x + 1, y + 3, white);
draw(x + 1, y + 2, x + 2, y + 4, white);
draw(x + 5, y + 2, x + 6, y + 4, white);
draw(x + 1, y + 5, x + 2, y + 7, white);
draw(x + 5, y + 5, x + 6, y + 7, white);
draw(x, y + 6, x + 1, y + 9, white);
6'b011000: // Y
begin
draw(x, y, x + 2, y + 4, white);
draw(x + 1, y + 4, x + 5, y + 5, white);
draw(x, y + 7, x + 2, y + 8, white);
6'b011001: // Z
begin
draw(x + 5, y + 2, x + 7, y + 3, white);
draw(x + 4, y + 3, x + 5, y + 4, white);
draw(x + 3, y + 4, x + 4, y + 5, white);
draw(x + 2, y + 5, x + 3, y + 6, white);
draw(x, y + 6, x + 2, y + 7, white);
draw(x + 1, y + 7, x + 8, y + 9, white);
6'b011010: // 1
begin
draw(x + 3, y, x + 5, y + 9, white);
draw(x + 2, y + 1, x + 3, y + 3, white);
draw(x + 1, y + 2, x + 2, y + 3, white);
6'b011011: // 2
begin
draw(x, y + 1, x + 2, y + 3, white);
draw(x + 1, y, x + 3, y + 2, white);
draw(x + 5, y + 1, x + 7, y + 4, white);
draw(x, y + 5, x + 2, y + 8, white);
draw(x + 2, y + 8, x + 8, y + 9, white);
6'b011100: // 3
begin
draw(x, y + 1, x + 1, y + 2, white);
draw(x + 6, y + 1, x + 7, y + 4, white);
draw(x + 2, y + 4, x + 6, y + 5, white);
draw(x, y + 7, x + 1, y + 8, white);
6'b011101: // 4
begin
draw(x + 4, y, x + 7, y + 2, white);
draw(x + 3, y + 1, x + 4, y + 2, white);
draw(x + 2, y + 2, x + 3, y + 3, white);
draw(x + 1, y + 3, x + 2, y + 4, white);
draw(x, y + 4, x + 5, y + 6, white);
draw(x + 4, y + 2, x + 7, y + 9, white);
6'b011110: // 5
begin
draw(x, y + 2, x + 2, y + 5, white);
draw(x + 2, y + 3, x + 7, y + 5, white);
draw(x + 5, y + 5, x + 7, y + 9, white);
draw(x, y + 7, x + 7, y + 9, white);
6'b011111: // 6
begin
draw(x + 5, y + 1, x + 7, y + 2, white);
6'b100000: // 7
begin
draw(x, y + 2, x + 2, y + 3, white);
6'b100001: // 8
begin
draw(x + 1, y, x + 6, y + 2, white);
draw(x, y + 1, x + 2, y + 4, white);
draw(x + 6, y + 5, x + 8, y + 8, white);
6'b100010: // 9
begin
6'b100011: // 0
begin
draw(x, y + 2, x + 2, y + 7, white);
draw(x + 5, y + 2, x + 7, y + 7, white);
draw(x, y + 7, x + 7, y + 8, white);
default:
begin
red = 0;
green = 0;
blue = 0;
endcase
endfunction
endmoduleCódigo: Seleccionar todo
Error (10731): Verilog HDL error at vh_sync.sv(76): function call char is not allowed here
