Macintosh Plus & Macintosh 512Ke
plusToo_250310.rbf
- Fix scancode for up-arrow and numpad key mappings (by robinsonb5)
- Fix sound with direct VIA control (by darylrichards)
- Control the Caps Lock LED on the keyboard
https://github.com/mist-devel/mist-bina ... s/plus_too
						plusToo_250310.rbf
firmware_250315
- Support prof'I'le strings in cores
- Allow selecting IDE hardfiles from the OSD
Apple //e
apple2e_250315.rbf
- Support saving/loading of CFFA's EEPROM
- Allow selecting the IDE image in the OSD (need fw 250315)
- AppleMouse // support in Slot 5
https://github.com/mist-devel/mist-bina ... s/appleIIe
zxspectrum_250315.rbf
- Add profile strings to quicly select a machine
- Connect the AY PIO used for RS232 to UART RX/TX pins
https://github.com/mist-devel/mist-bina ... s/spectrum
Apple //e
apple2e_250315.rbf
Commodore Amiga
minimig_mist_rtg_250324.rbf
- Major update, refer to git history for changes
https://github.com/mist-devel/mist-bina ... inimig-aga
firmware_250604
- Reconfigurable DB9 mapping in OSD
- usb: fix possible hang during parsing malformed device descriptor
- Fix extension handling in file selection (affects Gameboy core)
- Add 68EC020 to Minimig CPU types
- Add IMG extension to hardfile selection in Atari ST cores
Amstrad CPC 6128
amstrad_250725_r005.8.16.9.6.rbf
Realise (debug hexa unplugged so it's more stable)
-Manual installation tests :
Use a 32GB SDCARD Alloc 32KB SDHC + Windows 11 + "Mobility Lab" Hub (USB+SDCARD+)
Defrag using WinContig : select File>object>Folder and .. select your sdcard device, then do Action>Defrag
-Test :
"come join us" 2024 pouet.ne
https://github.com/mist-devel/mist-bina ... es/amstrad
-Test :
Amstrad CPC 6128
amstrad_250820_r006.1a
Experimental version
-Revision of 16kHz (4th menu : VGA:scandb50Hz) => not tested
-Revision of 32kHz (3th menu : VGA:original (scart signal, you can press enter if screen turn black) => not tested,
-cool osd menu
-cool osd menu
Amstrad CPC 6128
amstrad_250826_r006.3b.rbf
beta - scandoubler KO
- scanlines in orange mode (VGA: scanlines72Hz and Screen: THSF_orange
- SCART not testable by me yet, I still don't get TV, but it's a refactor scandoubler copied from sorgelig, but 2x, not 4x, so I don't know if it is running, blind another type. Choose OSD VGA:, press 3x "enter", if signal is off, just press another time "enter" to come back into VGA vram version.
firmware_250908
- Add CFG_FILE_N option to arc files for Minimig (by UzixLS)
- Custom file processor framework (Manuel Teira)
- Handle Ultimate2-style IDX files for C64 TAP files
FPGA64
C64_250908.rbf
- IDX file support (need new firmware)
- Profile strings for quick machine selection
- Reset doesn't reset current tape position
- Fully connect external UART pins
- Replace MIDI ACIA
- Press the right SHIFT for combined keys (like F2/F4/F6/F8)
https://github.com/mist-devel/mist-bina ... res/fpga64
Luxor ABC80 FPGA
ABC80_250908.rbf
- Support the swedish caracter set (regenerate ROMs!)
- Keyboard update
- Sound chip fixes
https://github.com/mist-devel/mist-bina ... ores/abc80
						C64_250908.rbf
- Replace MIDI ACIA
Luxor ABC80 FPGA
ABC80_250908.rbf
- Keyboard update
- Sound chip fixes
Amstrad CPC 6128
amstrad_250910_r006.4b.rbf
- Add VGA:C64 palette
