jorsus
Mensaje por jorsus » 31 Ene 2026, 19:07
OneChipMSX
msx_mist_260131.rbf
- Modules updated to v3.9.2 including the latest KdL Github fixes up to 25th of november 2025.
Details available here : https://github.com/gnogni/ocm-pld-dev/b ... istory.txt
- Replaced the YM2413 (OPLL) sound module core with IKAOPLL which is a cycle accurate version of the chip for better sound accuracy matching the real hardware.
https://github.com/tdelage26/mist-binar ... /cores/msx
jorsus
Mensaje por jorsus » 04 Feb 2026, 13:17
Timex Sinclair TS2068
ts2068_MiST_260203.rbf
- Based on Kyp069 source code
- BIOS file ts2068.rom needs to be placed in the same folder as the core
https://github.com/tdelage26/mist-binar ... res/ts2068
jorsus
Mensaje por jorsus » 16 Feb 2026, 18:13
Commodore 64
C64_260213.rbf
- Fixed 1351 mouse logic for games like Bricks 'n Balls or Duck Hunt where mouse buttons couldn't be used as joystick Fire button.
https://github.com/tdelage26/mist-binar ... res/fpga64
jorsus
Mensaje por jorsus » 09 Abr 2026, 00:25
Commodore 64
C64_260408.rbf
- Fix for 1351 mouse buttons handling in some games (bricks 'n ball, duck hunt)
https://github.com/mist-devel/mist-bina ... res/fpga64
Commodore Vic20
vic20_260408.rbf
- IDX tape file index support
https://github.com/mist-devel/mist-bina ... ores/vic20
jorsus
Mensaje por jorsus » 10 Abr 2026, 16:26
firmware_260409
- New RTC driver for PCF85263,DS3231 via MCP2221 USB/I2C bridge (thx to Eugene Azarov)
- 64 bit core_mod for ARC files
- Serial sink support (by teiram)
- Menu Page plugins (by teiram)
- Refactoring of IDX file support (Maverick-Shark)
jorsus
Mensaje por jorsus » 07 May 2026, 14:20
Amstrad CPC
amstrad_260507_r007.2c.rbf
- Merge with amstrad_220819_r005.8.16.9.6[c3].rbf for enabling VGA:scandb50Hz
https://github.com/mist-devel/mist-bina ... es/amstrad
jorsus
Mensaje por jorsus » 11 May 2026, 18:49
Amstrad CPC
amstrad_260511_r007.3a.rbf
- scandb50Hz resolution ok but missing great output of LineCounter into PPI I suppose
jorsus
Mensaje por jorsus » 12 May 2026, 20:26
Amstrad CPC
amstrad_260511_r007.4a.rbf
- regression demo
jorsus
Mensaje por jorsus » 15 May 2026, 01:12
Amstrad CPC
amstrad_260514_r007.5a.rbf
- wip interrupts
jorsus
Mensaje por jorsus » 15 May 2026, 20:09
Amstrad CPC
amstrad_260515_r007.6a.rbf
- tempest @50Hz
amstrad_260515_r007.7.rbf
- Batman 50Hz
